Is there a way to attached screenshots per test case step and export to Word to create training material?
Hello Johan,
We want to release new version of SuiTest (currently TestFLO) soon (v3.1). In new version we will add functionality of exporting Test Cases to html and probably doc/pdf.
If you are interested in what we want to do in SuiTest (currently TestFLO) then check our roadmap.
Best Regards
I think you can use markup (same as in Comments and Description). Exclamation mark should do the trick.
