Is there a way to load last comment on a jira ticket to Confluence page?
Bea Tea
Trying to load information directly from Jira to program reports and confluence pages.
Is tthere a way to load jira ticket with the last comment on the ticket using the macro? I don't see the option of comment in our jira instance.
3 votes
Julien Peyrade _ Elements
Hello @Bea Tea
There is no solution out-of the box.
However, you can do this very simply with a Jira add-on :  Elements Publish to Confluence .
Full disclosure: I'm the Product Manager of the app.
With our app you can create Confluence pages from Jira issues. It lets you :
  • insert any Jira issue data in the Confluence page (and keep the value synchronized between the issue and the page if needed)
  • including comments (you can decide if you want all the comments or just the last one)
You can read this short tutorial to see how : Copy Jira comments to Confluence pages.
This plugin can be used with any Confluente templates or pages, so it will not change your existing process.
The app is free for 30 days, (and stays free if your instance is under 10 users), so feel free to give it a try, and don't hesitate to tell reach our Support if you have any question.
Julien
Harald Seyr
October 27, 2022
Hi @Bea Tea
there seems to be no direct simple solution for this supported by some out of the box functionality, but other users solved this by
  • adding a Jira custom field for last comment to the issue
  • create automation to fill the custom field with the last comment (this duplicates data from level of commet to an attribute on issue level)
  • configure the Jira issue macro in confluence to show the custom field
Examples can be found in the community, e.g. at Solved: How to show Jira issue/filter last X number of co... (atlassian.com)
Harald
Bea Tea
Thank you will give it a shot
Sayed Bares _ServiceRocket_
Hi Bea, Are you using Confluence/Jira Cloud or Server/DC?
Bea Tea
I'm not sure
