Is there a way to render the Jira Issues macro to use the Wiki Renderer?
Jonny December 4, 2024
We use the Jira Legacy macro in our release notes, however we can't control the column width of this macro, which is really frustrating.
If we use the Jira Issues macro, we can adjust columns, but we lose our formatting from the relevant Jira fields.
Any ideas?
Stiltsoft support
Hi, we can also suggest trying the app that we develop - Table Filter, Charts & Spreadsheets for Confluence (maybe you already have it installed for your instance).
Our Table Transformer macro can help you to adjust the Jira macro column width without loosing the original formatting
Andy Heinzer
December 6, 2024
Hi @Jonny
I created a support case on your behalf over in https://getsupport.atlassian.com/servicedesk/customer/portal/48/PCS-353877
Someone from our Confluence support team should be better able to address this concern.
Andy
Jens Schumacher - Released_so
Hi @Jonny, could you share a bit more about the type of information you’d like to include in your release notes? A screenshot or example would be great—it could help us explore alternative solutions that might better address your needs.
