JIRA Issue/Filter Macro not displaying info
johan_ferner October 24, 2018
I want to display jira time fields in a confluence page using the Jira Issue/Filter macro as a table but they are only displaying as dates.
When viewing the Jira issue in Jira they are displayed as date+time.
Am I missing something?
AhmadDanial
October 30, 2018
Hi there, Johan.
I had this tested on the following environment and was able to confirm that the Created and Updated column only show the date instead of date & time.
  • JIRA Server 7.1.2
  • Confluence Server 6.1.1
JIRA
Confluence
  • May I know specifically which version of JIRA and Confluence you are running on your end?
  • Are you referring  to the Created and Updated field column in the filter or other custom field instead?
  • Do you happen to use any third-party add-ons on JIRA that enables the column to display the time as well?
Looking forward to hear from you soon.
