×Does the JIRA Issues macro in Confluence display the "Work Ratio" field in table view? I am able to add the column to the JIRA Issue Macro, but the column is blank. When clicking the "View matching issues in JIRA" link generated by the macro, I can then see the Work Ratio listed on JIRA in the Issue Navigator. Am I doing something wrong? Is anyone else able to see the percentage number?
To reproduce:
Thank you for your time.
Hi Douglas, it sounds like a bug to me. I took the liberty of creating this bug report. You may consider voting on it and adding yourself as watcher to receive updates.
Cheers
Just came across the same issue! Thanks guys!
