×Hello,
I want to create a table transformer query of two tables that show the Defact and its Resolved By linked Fix Story.
Problem is here if Defect links to a Story via a relates to link, then my view will show the Story if it resolves any other defect.
How do I do it correctly? Thanks
Hey @Matthias Mödinger ,
Are you using any of the apps listed here? I haven't used any of them but if no help is provided here, you can always reach out directly to the vendor by navigating to the app (or vendor profile) and using support links or emails provided. E.g. 👇
Tobi
