×Hi Atlassian community,
My product Team uses confluence to create A PRD doc and the way confluence suggests today is not enough.
I want to check if the following flow of creating PRD with Confluence<>Jira integration is possible somehow.
The flow:
If someone knows about something like that please let me know !
+ Every other way /add-on that can automate and make he PRD process in one place and easier will help as well!
Thanks in advance for any help in the matter,
Assaf
@Dave Liao Thanks for the answer ! I looked at it, maybe it will help but Im not sure when it will be released.
Anybody else maybe knows if there is a solution like this?
Thanks for any help !
Confluence Cloud will be getting Automations soon, which might let you tightly-couple Jira and Confluence in the way you’re describing: https://support.atlassian.com/confluence-cloud/docs/what-is-confluence-automation/
With the current Cloud feature set I don’t believe this is possible, but hopefully I’m wrong.
