×Hello, we have the same problem with Confluence 5.8.15. I can't find any ticket related to this issue, is anybody taking care of this, as it is apparently a bug? Thanks a lot.
This is a community forum. This isnt a support system.
The fix is in Confluence 5.9.x. Upgrade to fix the problem.
Hello, have the same exact issue in Confluence 5.8.9
Any way to fix this? I can't upgrade my enterprise Confluence.
Unfortunately, I have verified that only one component is still listing for our Confluence 5.8.13 instance.
While testing on Confluence 5.9.5 instance, I can see multiple components listed.
I tried this on my own space and I see the following – Can you confirm that this doesn't work for you? (Note the multiple component/s at the end of the image)
image2016-9-9 10:10:29.png
