Is there a way to implement the point system that is available in Confluence where a user receives points when giving an answer, asking a question and/or answer gets accepted.
Is there a similar plugin or native to JIRA that gives points when the assigned user gets to complete the issue or moves the status?
Thanks.
Nothing native to Jira, but...
Check out this plugin: https://marketplace.atlassian.com/plugins/com.bugpotion.jiraffe/server/overview
You an write custom rules to reward different amounts of points for different actions.
Thanks for this. I was able to check this out and seems this is the only option for version 7.1 . I have tried applying this but encountered alot of errors. Thanks anyways.
