Jira Issue Filter not Displaying "Images" when embedded in Confluence
Nikki Leonard
Jira Issue Filter not Displaying "Images" When embedded Confluence
I am attempting to build in some quality reporting in to procedural execution within Confluence. We will use Jira sub tasks to execute the procedure and record images, comments, anomalies, etc. Using the Jira filter macro embed in confluence, I am able to pull in important fields such as status, assignee, reporter, etc. However, when I select "Images" The field registers but the image does not populate as it would in Jira advance search. See attached screenshots. images-jira-filter-results.pngimages-not-displaying-confluence.png
Does anyone know how I can get the images to show on the confluence page?
Fabian Lim
Hi @Nikki Leonard
Is the image field in jira a 3rd party custom field?
Cheers
Nikki Leonard
No I believe this a Jira system field it is pulling in Jira whatever attachments are added to the issue and/or comments.
Nikki Leonard
Checking in here - any advice?
Fabian Lim
Hi @Nikki Leonard
I suggest you open a ticket with Atlassian to investigate.
Matt Doar
