I have a defects/bugs logged in Jira and they are all differentiated based on "Labels", I am using Jira issue/Filter' macro to dynamically query the 'count of issues' for each label. The issue is that the count is not updating by itself when I added new bugs with the specific label. I have to click 'edit' and then publish changes again for the count to increase or decrease.
The table is shown below.
Sr. | Category | Defects |
1 | Category -1 | |
2 | Category -2 | |
3 | Category -3 | |
4 | Category -4 | N/A |
Please let me know if there is. I would be grateful.
Hi @Sehreen Jafry, Welcome to the community.
If the JIRA issues macro is not refreshing automatically then just set the JIRA Issues macro's cache parameter to off or flushing the cache in Confluence.
1) There is a "cache" parameter that can be switched to off.
The macro maintains a cache of the issues which result from the JIRA query. If the 'cache' parameter is set to 'off', the relevant part of the cache is cleared each time the macro is reloaded. (The value 'false' also works and has the same effect as 'off'.)
Note: This parameter is available only if you insert the macro via wiki markup or by editing the storage format of the page. The macro browser does not offer this parameter.
(or)
2) You can flush the cache by following below steps:
Go to Confluence Admin > Cache Statistics, and Flush All
Refresh the page and check the new status.
Ram.
Thank you for your reply. I asked my Confluence admin regarding this option ( as I have limited access) but she was of the opinion that clearing cache might end up clearing the confluence pages in Draft state. So all she did was run a 'macro repair' function which she found in the admin area and I think it might have done the trick as the macros are updating on reloading the page.
Hello @Sehreen Jafry
Isn't the count updated automatically when you refresh the page, i.e. you add a new bug in jira with a certain label and then you refresh the confluence page, that should refresh the count.
Unfortunately, that's not happening.
I have added a pie chart macro to the page as well, and it updates every time I refresh but the 'Jira issue Fitler' count refuses to budge. Its only when I click 'Edit', and go into the Edit mode, the count updates.
Is there a solution for this? I have the same issue as well. How do we get the Jira issue filter to auto refresh? Please help!
