I have created a form using Scaffolding. When I try to create a Jira Issue from one of the text fields of the form, I get warning message that Jira issue was created but there is a problem adding it to the page. The link to Confluence page is not visible from Jira issue either.
If a field is not part of Scaffolding form, everything works fine, but then this field has to be edited separately which is really annoying.
Is there a way to solve it?
Thank you
Hi!
We would be happy to help you. Could you raise a support ticket on - our Success Support Portal? You can sign up/login on this page https://success.servicerocket.com/support/servicedesk/customer/portal/3/create/45
Hi Samuel,
thank you for reaching out, much appreciated. I have created the ticket SRSUP-2161.
