Load Test procedure in Linux for JIRA and Confluence
naga raja August 17, 2017
Can any body please let me know how to do the load test on my JIRA and Confluence setvers(app,web,db). Its urgent
Nic Brough -Adaptavist-
August 17, 2017
You'll need to build the tests you want to perform using load testing tools.
There's a doc on https://confluence.atlassian.com/enterprise/jira-performance-testing-available-tools-729743538.html for doing JIRA and the same basic principles apply to Confluence, although you will need to remember that the data is a very different shape in the two systems.
I need scripts to perform load test on both JIra and Conflence servers
August 17, 2017
Ok, you'll need to write some to test what you want to test.
There are some jmeter ones for older versions of JIRA and Confluence that Atlassian used to use, but I'm not aware of any for more recent versions, or if any other users have ones they're willing to share with you for a starting point.
Could you  please suggest , what are the list of scripts we have to run in linux server for both JIra and Confluence
August 17, 2017
I don't know what you mean by that.
Thanks for your information.
Required applications would be JDK1.8 and Jmeter3.2
