connection problem between jira and confluence
Jean-Michel Duvivier April 7, 2022
Hello, since the update of confluence in 7.13.4 and jira 8.22. we have lost the links between application. Confluence link in jira: error says enable OAuth in confluence (how to enable OAuth?) jira link in confluence: we have lost the link (how to create a new link and where to find the keys?
Fabio Racobaldo _Catworkx_
Hi @Jean-Michel Duvivier ,
first of all your links are not lost but they will work again after that Application link issue will be fixed.
Please, go to Application Link (Admin->Applications->Application links) for both Jira and Confluence and set, as authentication, "OAuth (impersonating)". After doing that please check Application Link Status on both side.
Hope this helps,
Fabio
No it's ko :
Are u sure that ports are correct? Can you try to use internal URL in "URL de l'application"?
url it's ok but : We cannot view the status of this application link because outbound authentication is disabled. How to activate it?
