Crowd Mismatch token while SSO between JIRA and thrid party app. Can someone assist?
Rahul Arora October 29, 2017
I am assuming that somehow my validation factor isn't good enough to accept the token for another application, though I can login into third party application and JIRA separately via crowd authentication. Here is the snippet of the logs:
017-10-29 06:04:41,604 http-bio-8095-exec-13 DEBUG [manager.token.factory.TokenKeyGeneratorImpl] Generating Token for principal: AroraRahul
2017-10-29 06:04:41,604 http-bio-8095-exec-13 DEBUG [manager.token.factory.TokenKeyGeneratorImpl] Adding remote address of 10.34.7.134
2017-10-29 06:04:41,604 http-bio-8095-exec-13 DEBUG [manager.token.factory.TokenKeyGeneratorImpl] Adding Random-Number of ValidationFactor[Random-Number=7647594814225824346]
2017-10-29 06:04:41,604 http-bio-8095-exec-13 DEBUG [crowd.manager.authentication.TokenAuthenticationManagerImpl] Current Validation Factors:
ValidationFactor[remote_address=127.0.0.1], ValidationFactor[X-Forwarded-For=10.34.7.134]
2017-10-29 06:04:41,604 http-bio-8095-exec-13 DEBUG [crowd.manager.authentication.TokenAuthenticationManagerImpl] comparing existing token Token{identifierHash='sLfTZcWbBQaW55xqhy9QRQ00', lastAccessedTime=1509271459529, createdDate=2017-10-29 06:04:20.0, duration=null, name='AroraRahul', directoryId=32770} with a validation token Token{identifierHash='ZUekGOFZ0GxdRxq5aFjLNw00', lastAccessedTime=1509271481604, createdDate=Sun Oct 29 06:04:41 EDT 2017, duration=null, name='AroraRahul', directoryId=32770}
2017-10-29 06:04:41,604 http-bio-8095-exec-13 DEBUG [crowd.manager.authentication.TokenAuthenticationManagerImpl$TokenValidationFailure] Existing token 'E4NHkpy3nQWUZSy9ghUDpA00' for user 'AroraRahul' does not match new token 'Ht61ZiIz09sl74cusjfcow00' with validation factors 'ValidationFactor[remote_address=127.0.0.1], ValidationFactor[X-Forwarded-For=10.34.7.134]'
2017-10-29 06:04:41,605 http-bio-8095-exec-13 DEBUG [crowd.manager.authentication.TokenAuthenticationManagerImpl] The token keys don't match
Rahul Arora
June 27, 2018
Actually my issue was occurring from third party side which was trying to access the crowd for single sign on and unable to pass x-forwarded IP to perform consistent IP address with my JIRA application and failing to match the token for SSO between Jira and third party app.
Issue was resolved when I added the code to pass x-forwarded IP to the crowd instead of remote IP address.
Matt George June 27, 2018
Awesome, nice one!
I've stumbled into this issue myself however we found that in Crowd we needed to untick the tick box that says "Require consistent client IP address" under the Session Configuration setting menu.
We were getting pretty much the same error message as you so if you're still having trouble I hope this helps!
Matt
Edwin Kyalangalilwa
October 29, 2017
Try clearing your browser cache.
