Hi Guys, whats up?
After a long time searching for a solution and not finding it, I decided to resort to writing in the community. I am trying to develop a plugin, by following the step by step, when running the atlas-run command, I get several errors regarding atlassian-spring-scanner, yet I get the guidance to access localhost: 2990 / jira but when accessing, no opens the authentication screen. Please help me.
$ java -version
java version "1.8.0_221"
Java(TM) SE Runtime Environment (build 1.8.0_221-b11)
Java HotSpot(TM) 64-Bit Server VM (build 25.221-b11, mixed mode)
$ javac -version
javac 1.8.0_221
$ atlas-version
ATLAS Version: 8.0.16
ATLAS Home: /usr/share/atlassian-plugin-sdk-8.0.16
ATLAS Scripts: /usr/share/atlassian-plugin-sdk-8.0.16/bin
ATLAS Maven Home: /usr/share/atlassian-plugin-sdk-8.0.16/apache-maven-3.5.4
AMPS Version: 8.0.2
Hi @Vinicius Sousa,
welcome to the Atlassian community.
I want to point out that this community is mainly focused on non-dev questions. Your question would be better suited in the Developer Community: https://community.developer.atlassian.com.
Having said that, please provide also some more information:
Matthias.
Okay, you're right, I'll go to https://community.developer.atlassian.com.
Thank you so much.
Recommended Learning For You
Level up your skills with Atlassian learning
Atlassian DevOps essentials
Learn how to build, automate, and improve DevOps processes used for the development and delivery of software and other digital products.
Tracking and improving DevOps metrics
Make informed decisions about current and future projects and deadlines to maximize your team's productivity and keep morale high.
Exploring Atlassian Cloud products for agile and DevOps
Coordinate a suite of Atlassian Cloud products for greater collaboration and trust, higher-quality solutions, faster releases, and more.
