Hi everyone,
I’m working on an automation rule in JPD to automatically clone an issue from our intake project to another JPD project immediately after submission. Specifically, I need to ensure that a short text field and a people field (@) is cloned exactly as entered.
To achieve this, I’m using the Clone issue action in Jira Automation and then configuring the Choose fields to set… option. In this configuration, I plan to map the value from the original field to the corresponding field in the cloned issue using a smart value, both fields have the same name but I can't find the field ID in JPD. My questions are:
1.How do I set the smart value so that it clones the corresponding field into the correct field of the other JPD project?
2.Are there any best practices or pitfalls I should be aware of when mapping fields between different projects, especially if the field names or IDs differ?
Any detailed guidance or examples would be greatly appreciated!
Thanks in advance for your help.
Hi @Hugo Maarten Fehmers -- Welcome to the Atlassian Community!
From my observations, Jira Product Discovery (JPD) is based upon team-managed project (TMP) features. And so the project-specific fields are distinct for each. While there may be common, global scope fields used, you may need to copy the fields using JSON and their custom field IDs to get the correct source / destination values in the Ideas. Here are some suggestions to help.
Finally, experimentation and testing are key! If you run into challenges, please post images of your complete rule, the audit log details, and explain what is not working as expected.
Hi @Hugo Maarten Fehmers and welcome to the community!
Cloning issues to a JPD (or team-managed projects) particularly when dealing with project-specific fields and JSON configurations can be a bit challenging.
If you are willing to use a third party-app, I can suggest using our app Deep Clone for Jira. This powerful tool is designed to streamline the process of cloning issues within Jira, ensuring data integrity and consistency. Deep Clone can clone issues/work items/ideas between team-managed and company-managed projects and will automatically match the custom fields based on field names.
