Hi Team,
Currently my product timeline view in Product Discovery shows by default the roadmap filed as a color indicator. I would like to configure a different filed there. Can someone help me how do I change that
I wanted these highlighted areas in timeline bars to be highlighted as per a customized column. I figured out the way to do it. Please consider this query resolved
Below is the way to customize it. In the Edit filed setting select the "Highlight rows and cards with this color" option
Hi @apriyadarshinee ,
As this is a JPD question I'll just move it to the appropriate Community product group.
Additionally, can you maybe share a screenshot/example of how the view looks at the moment and which fields/visualizations you'd like to add/update there?
Tobi
