I created a new roadmap project but am unable to do anything with it. I clicked on Projects from the top navigation and clicked on New project. Then I selected Product Roadmap and I clicked on Use Template. I filled out the required information and the new project was created. However, when I view the project, the only item I see in the left navigation panel is Project Settings. How do I access the template and all of the views that are part of the Roadmap project?
Hi Michelle, you should be able to see pre-configured roadmap views. Can you try to refresh or log in and out to see if that resolves it?
If not, I recommend to delete this project and start a new one. Please let me know if any of these suggestion don't resolve your issue.
I was able to play around with settings, log out and upon logging back in, all the widgets became visible. Thank you for the response!
