Is there a way to export all insights from Product Discovery Ideas?
Cody Reeves
March 11, 2025
We need a way to export all insights from our Product Discovery tool, ensuring that each insight is attached to its respective idea.
The export should be available in CSV and JSON formats for further analysis and integration with other tools. Requirements Include all insights. Not just count
Each insight must be linked to its corresponding idea.
Export should contain relevant metadata, including:
  1. Insight content (description)
  2. Associated idea (title)
  3. Tags
  4. Date created
Amina Bouabdallah
March 14, 2025
hi there! we don;'t have yet the ability to export insights. Why do you need to export them? maybe there is a different solution to the underlying problem you are trying to solve
Have a nice weekend
Amina
Cody Reeves
March 14, 2025
We were hoping to get enabled from LLM based processing to discover trends and patterns in the insights that are collected as well as provide high level overview to our stakeholder of the feedback collected.
Would you know any path to achieve getting the insights out to a CSV or all in one place to complete an analysis?
Tanguy Crusson
March 17, 2025
You could export the insights using the API. there's an example here: https://github.com/Jira-Product-Discovery-Integrations/polaris-forge-ref-app/tree/master/get-insights-example
