Jira Product Discovery - Project Settings
Kshitij Raval
August 5, 2024
Recently we have started using Jira Product Discovery. I have "creator" access, however I do not see "Project Settings" menu option on the left pane. What settings/steps/access do I need to see "Project Settings".
For the Jira Product Discovery project, I want to do is:
1. Change the project name
2. Add few new fields
3. Give view access to everyone on the team
Kshitij Raval
lila
Hey Kshitij, you need to be an admin also to be able to do that. You might want to check with your jira admin to make you and admin on that project to be able to see the panel and make the amends you are after.
