Making JPD Dates look 'pretty' when copying into Jira delivery
Kate
I have an Automation in JPD that when an idea meets certain parameters, a ticket is created in a delivery project. As part of this automation, details like the Reporter Name and Due date are copied into the Description field.
In the JPD space, the Delivery Target Date is custom field '11517'.
What I am hoping is that someone has figured out a way to make the display of the date from JPD look user friendly/pretty?
The best I have found is the smart value
{{triggerIssue.customfield_11517.match(".*end\":\"(.*)\".*").toDate}} which has the output 2025-03-31T00:00:00.0+0000
Has anyone come up with anything else? Bonus points if it matches a DD/MM/YY (aka NZ/Aus) date format
2 accepted
Bill Sheboy
February 18, 2025
Hi @Kate
The JPD dates are formatted as JSON, although they are recognized as text in rules.  With the new function jsonStringToObject(), the dates may be accessed with their attributes.
For example, this would access the "start" attribute:
{{jsonStringToObject(issue.customfield_11517).start}}
And if you needed a different date format, the text may be converted to a date then formatted it as needed:
{{jsonStringToObject(issue.customfield_11517).start.toDate.jiraDate}}
Kate
Oh, thank you for the options and even more so for the explanation. I will give these a go now!
Like Bill Sheboy likes this
Marek Bujak
My idea was {{issue.customfield_"JPD-Date-Field".jsonEncode.left(23).right(10).toDate.jiraDate}} and it seems to be working
Kate
Oh, thank you for this, will give it a test now :)
