All the months for 2025 are grayed out when I try to change the range on my Roadmap's Timeline view, therefore I can't see any projects targeted for this year.
My best guess would be this problem occurs when you are trying to edit the Timeline start date to a date which is before the current Timeline end date - because a start date needs to be before an end date.
I would suggest first setting the Timeline end date to some quarter in 2025 or 2026, after which you should be able to set the Timeline start date to Q1 2025.
Hope that is of help.
Yes, that's exactly it, thanks @Mart Postma
