Automation to align status between JPD and Jira
Rebecca Graf
Hey all,
I'd like to create an automation, which checks if a status of delivery tickets in Jira is aligned with the JPD ticket (only in a certain JIRA project).
The challenge: Our workflow in Jira is different from JPD, meaning that I need a mapping like
if status in JPD is A please set status of linked issue in Jira project X to B
 if status in JPD is C please set status of linked issue in Jira project X to D
and so on...
The automation should run regularly without being triggered by a status change. How do I set it up properly?
Thanks for your help :-)
Best
Rebecca
Nick Haller
September 10, 2024
Hi @Rebecca Graf ,
An automation like that one below should work for the use case - which uses multiple IF / ELSE components to map each JPD status to Jira status:
1) WHEN: Issue transitioned
2) IF / ELSE
  • Status = "JPD status A"
3) Branch rule / related issues
  • Type of related issues = Linked issues
  • Link types = is implemented by
4) THEN: Transition the issue
  • Destination status = "Jira project X, status B"
5) IF / ELSE
  • Status = "JPD status C"
6) Branch rule / related issues
7) THEN: Transition the issue
  • Destination status = "Jira project X, status D"
^ And so on depending on how many JPD idea statuses you want to map to Jira issues statuses.
So each IF / ELSE component should be tied to the top WHEN: Issue transitioned component, and each IF / ELSE component branches after to look for the delivery ticket.
If an IF / ELSE component does not match (Ex: steps 2-4 above), the automation will then check the following (Ex: steps 5-7 above), and so on, until a there is a match - then stop reviewing the following IF / ELSE components after the match.
Hope that helps! Let us know if you have any questions.
Rebecca Graf
Hi @Nick Haller , thank you so much for your explanation, that definitely helps.
Just one more question: Would it be possible to run this automation without a specific trigger (step 1) but on a daily basis? There can be usecases, where we'll have a mismatch between the two tools and I'd like to cover them as well (without waiting for a transition in JPD).
Haven't done anything like this before and didn't find an explanation how to run an automation regularly without trigger.
Best regards
Rebecca
Nick Haller
September 11, 2024
Hi @Rebecca Graf ,
Yes I believe that should be possible with something like this is as the main trigger instead:
^ Where the automation is scheduled to run daily (or depending on your use-case).
Notice I also added a JQL to specify that this automation only executes for my JPD project / ideas - which will help narrow down the number of times this actual runs.
Glenn A
I'd love to do the reverse: if status of Jira Epic is "Done", change JPD Idea to Done. I am admin on both the JPD project and the Jira project. If I try to create the rule in the Jira project, it excludes the JPD project and I am unable to add it to the scope in the "Rule Details" section (as suggested in the rule building UI).
What am I missing?
Thanks!
