×I have a simple automation that archives ideas every working day at 11:30 PM if the idea has a specific status.
status IN ("Migrated to DEV", "Offer Denied", "Won't Do") and "Idea archived[Dropdown]" is EMPTY
The automation worked fine until an Atlassian release. (I guess)
I can change to:
status IN ("Migrated to DEV", "Offer Denied", "Won't Do") AND "Idea archived" is EMPTY
and the validation does work, but the same error appears in the audit log.
So the Audit log shows:
I find the "Idea archived" field in the custom field section, but I have no clue how to find the correct name to add it to my JQL.
It could be a problem with the fields:
Any solutions?
Thanks!
Hi Dominik,
My team faced the same issue lately. After working with Atlassian Support, we discovered that this is due to a backend change they're making to migrate the Idea archived field to a single global field, rather than separate project-specific fields. Right now, however, there's both a global field and project fields, so the error you're receiving indicates that automation is unable to determine which one to use.
According to support:
Our team will soon migrate all project-scoped fields to global fields to allow consistent use of automation rules across all projects without needing to identify specific field IDs. However, we don't have an exact timeline on when it will be rolled out to all our users.
In the meantime, your automation rule will need to be updated to reference the project-level field ID specifically. You can verify the global and project field IDs by following these steps:
Let me know if you'd like more clarification!
Jeremiah
Thanks @Jeremiah Rappley
I was successful with 1 and 2 - but for 3, I don't know where to include this information in my automation.
I found the two Custom Fields (customfield_xxxx1 and customfield_xxxx2)
The automation was working, but the issues are still not in the archive.
I tried with both custom fields using it in the "Then" Advanced Section in the Automation as
"fields": {
"customfield_xxxx1": {
"value": "Yes"
Hi @Dominik
I just tried to archive an Idea with a rule and it worked for me, as you tried with JSON.
When using a JSON expression to update a field, please note:
Ensure the field is not selected from the dropdown list AND in the JSON expression, as only one may be used at a time for a single Edit Work Item action.
Thanks @Bill Sheboy
In the trigger my JSON is:
project = IDEA AND status IN ("Migrated to DEV", "Offer Denied", "Won't Do") AND "Idea archived" is EMPTY
And my Then section is
The JSON finds the right issues and the automation has no error. But the issues are not in the archive.
Any idea what's wrong?
Just to align on terminology...
Back to your question, let's confirm you are changing the correct field with that ID, using this how-to article:
yourJiraURL/rest/api/3/issue/yourIdeaKey?expand=names
@Bill Sheboy Thanks a lot.
Right now, my JQL does not find any tickets, because the automation (JSON) sets the "Idea archived" to yes.
BUT - in the UI, the ticket is not in the Archived View.
I compared an archived ticket and a ticket that is not archived after it went through automation. I extracted the code sections regarding the Idea archived field.
This brings me to the conclusion that my JSON is not doing what it should.
Maybe I have to wait for the Atlassian guys, but I'd like to try further.
So what could be the solution looking at my THEN section
Hi @Dominik apologies for the inconvenience. From your previous messages, it seems that your setup is correct, but you're using the global field for archiving.
We published an article on this topic yesterday, which you can follow to ensure everything is set up correctly: https://community.atlassian.com/forums/Jira-Product-Discovery-articles/Notice-Automation-Jira-Filters-and-workflows-on-archiving-fields/ba-p/3008866
Paying particular attention to step 13 might be helpful for you.
In summary:
Even though the ideas have a "Yes" value in the global Idea archived field, they don't appear as "archived" right now. This is because the archival state is currently managed by the project-level fields (for you, customfield_10086). As we move forward with our migration, your project will begin using the global fields. At that time, the archival state will be controlled by the global field, and those ideas will move to the Archived view correctly.
If it doesn't bother you that these ideas appear in your regular views for the next few weeks, there's no need to make any changes. Otherwise you can follow the article I linked to set up a duplicate automation rule with project-level field.
If you require further assistance, please let me know. If you'd like us to take a closer look, feel free to open a support case as suggested by Amina and Tanguy.
hi there! sorry for the inconvenience. We would love to help. To reproduce, Atlassian needs access to your instance. To get access to your instance, we need a support ticket to be opened.
Any chance you might open a support ticket?
Thanks!
Amina, JPD PM
To open a support ticket, you can do it directly from Jira Product Discovery, from the place where you can send us feedback (usually on the left sidebar > Give feedback > get help from the support team)
Just paste the following:
"Amina Bouabdallah from the JPD team asked us to create a support ticket to investigate an issue we're facing with Automation rules in JPD. The Slack thread where the issue is being discussed is https://atlassian.slack.com/archives/C05EZGA8XKL/p1745329380278069 . Thank you. "
Hi @Dominik
Here is an update. We are making JPD system fields global, in 2 stages:
Stage 1: any new JPD project created since Mar 14, 2025 has system fields that are global.
Stage 2: all existing JPD projects' system fields will be made global. We're targeting May 31, 2025 for this change.
Thanks to your post, we identified an issue that affected a small number of customers, due to the roll-out of the first stage: some automation rules, Jira filters and workflow rules using the fields used to “archive” ideas today stopped working. If this impacted your site, this post explains how to fix it.
We do apologize for this: the team tested every possible scenario many times over - or so we thought - but this issue was missed.
Here is the community post describing the fix to the issue you are facing. Any chance you might let us know if it helps?
Best
Amina
Hi @Dominik,
Does the JQL query work in the issue search view? Switching from basic search to JQL gives me this query:
status IN ("To Do", Done) AND "idea archived[dropdown]" is empty
If the JQL query is buggy, using the "Idea archived is empty" part as a separate condition in your automation should fix the issue:
Hope this helps!
- Manon
Thanks @Manon Soubies-Camy
it does not work - but I will follow @Jeremiah Rappley s comment as it seems he had the same problem and has a statement from the Atlassian Support.
