Limitations in Jira Product Discovery
scuryova June 20, 2024
hi there,
Is there a plan to remove (some) limitations in Jira Product Discovery?
I am specifically asking about "Field Options per Field" limited to 500.
We have a custom field in JPD indicating which Customer the Idea is concerning and our customer baseline is far beyond 500. It is very limiting indeed.
Any thoughts/feedback?
Thank you.
Katarina
Field options per field
500
Reference: https://confluence.atlassian.com/jpdkb/jira-product-discovery-limits-1402415682.html
Tanguy Crusson
June 24, 2024
@scuryova Jira Product Discovery is built on Jira, and Jira slows down the more options you add to a field. It can get pretty bad. For now we don't have plans to lift this limit.
However we do plan to integrate with the "customers/organizations" of Jira Service Management and surface those as a field - for this exact use case.
uri.shani June 27, 2024
@Tanguy Crusson
I'm having the same issue.
I tried deleting options, already deleted ~20 but still getting the error "This field has reached its maximum of 500 options"
What else can I do?
uri.shani July 4, 2024
@Tanguy Crusson resurfacing this one - this is really causing issues fro us.
scuryova July 4, 2024
@Tanguy Crusson - Are you saying that we will be able to use the custom fields in JPD created outside of JPD? JPD is a team-managed project, isn't it? So, in general (if I'm not mistaken) in the team-managed projects, it is possible to pull the custom fields created in Jira Software. This would actually be an awesome solution. Because currently we do duplicate custom field "Customer" - we have one Customer field in Jira Software (almost 2000 drop-down values) and another one in JPD (only 500 allowed). Which also "complicates" filtering, dashboarding, for example. So, instead of having 2 fields, we could have just one.
Tanguy Crusson
July 4, 2024
@scuryova yes, if you open Project settings > Fields from a JPD project, you should be able to add a global field from Jira into athe JPD project. I haven't tried with a field with such a large field so no idea how good the performance of the UI will be with it though - it's probably worth testing on a test project first.
uri.shani July 7, 2024
@Tanguy Crusson  did you see my question? need help please
Danny
June 20, 2024
Hi @scuryova
Good question, sounds like the answer should come from Atlassian's JPD Product Owner or the JPD team.
Danny
@Tanguy Crusson - Any feedback from your side? Thank you.
