I've added a custom field called "Status updated". Then created an automation to populate that field with issue.updated whenever that field value is changed.
The trigger seems to work according to the logs but updating the field does not.
I've included a screenshot of my automation and pasted the output from the logs at the bottom. Is anyone able to see what I'm doing wrong here.
Note: I've tried using the custom field ID and the name of the field. Both give the same error.
Log output:
Hi @Owen Vachell and welcome to the Community!
Have you added the field to the edit issue screen for the issue type you are trying to update? Jira can only edit fields if they are on the edit screen.
Hope this helps!
Thanks for your reply. I don't see any screens that my project is using. Currently unsure if this makes a difference but this is in Jira Product Discovery. Reason I mention it is because I also can't see my custom field if I go to the main Issues settings page. Even though it's there in my JPD project. I wonder if JPD supports what I'm trying to do.
I was sure I selected a company managed project when creating this.
Hi @Owen Vachell -- Welcome to the Atlassian Community!
Adding to the suggestions from @Walter Buggenhout ...
You note this is for a Jira Product Discovery (JPD) project. What type of field is this and where was it added?
And so if this a JPD "date" field, the time cannot be saved from {{issue.updated}}. A workaround would be to store the value as text and convert it to date / time when needed.
Hi @Bill Sheboy and thank you.
I've been doing some digging and starting to realise this. Thank you for confirming.
My ultimate aim is to have a column that tells me how long an issue has been sitting in its current status. So, for example, if something has been sitting in its current status for 90 days, it's an indication we either need to decide it's not important enough or make an effort to decide where it fits in the roadmap.
Do you know if this is in anyway achievable. Unsure if I'm going about this the right way.
Thanks for those additional details, Owen!
For a JPD project, doing what you ask would require two custom fields and two automation rules:
One challenge with this approach is if Ideas go backwards in flow, the count is reset and not cumulative for the time in an earlier status. To do that, you would need a marketplace app to better track the time in status for a JPD Idea project.
Thanks again @Bill Sheboy I was starting to go a similar route. But with just one integer field and an automation that sets it to zero on status change and another to increment it by 1 every day.
However, my biggest issue at the moment is that the automation still can't find my custom field.
Would you please post images of:
Those may provide more context for why the field is not found. Thanks!
note: I've changed "Days in status" to "Weeks in status" to reduce the number of automations I'm running.
The likely cause is the JSON syntax is incorrect, even though the error message does not state that specifically.
If that field is a number type, here is the correct syntax for the JSON:
"fields": {
"Weeks in status": 0
That's how my JSON looked in my OP. I was experimenting with both formats. Same result.
Is the the field a number type?
One last thing to try: change the JSON to use customfield_10225 rather than the field name. Rules can get confused by duplicated field names / smart values when they are in different scopes: e.g., global versus team-managed (TMP) versus multiple TMP projects.
