Hi everyone! I am trying to publish a view in JPD, and having some trouble setting the published description.
In my view, I click Publish > Settings > and see Published description as the bottom setting. The dropdown will change from black to blue when clicking, but the dropdown itself doesn't render, so I can't select a custom description field for my custom view.
Without the ability to set a custom description field, we would be exposing our internal notes to a wider audience than intended, which is a non-starter. Is there a workaround here? Could this simply be a bug?
Thank you in advance for the insight/help!
Hi Brittany,
This is indeed a known bug, we are currently working on it.
Sorry for the inconvenience, and thank you for your patience,
Best Regards,
Hermance
Sr. Product Manager @ Jira Product Discovery
Hi @Brittany Messing ,
I'm just going to move this to the specific product/app group so the team can help you there.
I haven't tested this myself, but have you tried checking if this can be replicated in other browsers (potentially incognito window as well)? Also, are other users experiencing the same issue?
Tobi
FYI -- I recall seeing a similar question in the last couple of days for this same symptom so this may be time to ping the Atlassian Support team.
