We're using the following impact score: 60% goal impact, 10% insights, 10% votes, 20% key customers.
I think there is an issue calculating key customers. We've added weights to customers.
As you can see in the photo below, it makes sense that #1 is #1. There is a big goal impact and lots of key customers.
However, the next 5 should not all be ranked the same. They all do not have insights or votes. And are all calculated with 4/5 goal impact. but, for some reason, the key customer weighting is not ranking the 5th one down higher than the others.
Any ideas?
Hi everyone, so the short answer is we have a bug on how we account for ideas that don't have a value for a field in the weighted score formula. We'll fix it!
Is this bug resolved yet?
Yes, it should have been fixed shortly after this message
Is "4" the lowest value you have for Key Customers?
If so, I believe the calcuation might be correct, because that lowest value will you a "weighted" score of 0 ("zero").
Let's try a rollup vs weighted for our "Product areas" (with weights, although not multi-select, but I believe that shouldn't make a difference):
Not sure I'm on the right track, though.
I continued digging a little. I'm pretty sure now that @Cassidy Fitzpatrick's issue is not specific to that very field, but maybe rather cause by how formulas and specifically, normalization, works with multi-select fields. From the documentation:
The normalized value x for a field is defined as 100 * (x - min) / (max - min)
So if "4" is the min value for Key Customers, this field contributes "0" to the Impact score.
I checked how Rollups and Weighted scores work for multi-select fields, and rating fields. Something seems off:
For the Rating-related formulas, you see 0 = undefined. And a rating of 1 gives you a weighted score of 20. One could argue whether "undefined" is really the minimum here. But so far, so good.
But for the multi-select field (weighted AARRR goals), undefined is just undefined - and a value of "1" gives you 1 in Rollup, yet "0" in weighted score.
@Tanguy Crussonor someone else from Atlassian team, can you enlighten us here?
You're right @Jan-Hendrik Spieth there is something fishy here:
You could also try creating a new "Impact Score" field and instead configure it to use a custom formula type. I prefer the custom formula because it's far easier to modify the formula expression if your criteria for how the Impact Score gets calculated changes later on.
Hi @Cassidy Fitzpatrick , could this be because of the "Votes" field? It's not on the screenshot you shared
I changed the vote percentage to 0 and there was no change! We also haven't started using votes yet as we're still setting up. Thanks for the idea though!
OK - we'll need to look into it, it could very well be a bug. In the meantime, have you tried creating a new "Score" field with the same configuration?
Thank you! I just tried that and no luck. It seems to work on our other boards so a little confused about what's up. Appreciate your help.
OK damn - would you be ok to jump on a Zoom early next week? https://calendly.com/tcrusson/15min-meeting So we can troubleshoot this together
