So this topic has become relevant as Atlassian has changed the automation package billing model for Jira Cloud.
JPD (Jira Product Discovery) has a limit of 500 Automations on Standard Plan, and currently I use automations to bridge the gaps of basic functionality limitations in JPD vs JS (Jira Software). It's important to note that to my knowledge currently there is no plan in Jira Product Discovery that supports more than 500 automations per month.
For Example:
Note: I already sent in a support ticket with my concerns, however, I wanted to also bubble up my concerns here in the community as I would say that the 500 automation limit in JPD is kind of ludicrous considering that the product just came out of Beta and there are still MASSIVE gaps in basic functionality that can only be bridged by leveraging Jira Software's powerful automations system.
@Mike Gargano I know this does not address your automation limitations, just a hint regarding your 2nd mentioned example - you can do custom weighting for select fields:
Hi @Mike Gargano ,
Today the limits for Automations in the standard plan are not strictly enforced since we don't yet have a premium plan. Also, the current limit of 500 was calculated based on current usage of the feature (only 4 customers had more). But when we launch a premium edition we'll revisit this. In the meantime, if you worry you'll hit limits please let us know and we can lift it up for you. (in your case, I've just asked the team to do so)
On your 2 use cases: thanks a lot!
Awesome news! thanks @Tanguy Crusson I look forward to the future of Jira Product Discovery that I know you and your team are hard at work on 💪
Also thank you @Michal Vit and @Tanguy Crusson I look forward to updating my JPD project to take advantage of the new custom weighting functionality!! 🍻
+1 here... We started adopting JPD and build a set of automation around it to make our PMs happy and productive (After transforming them from Productboard).
We encountered the same issue with automation usage limit and we cannot upgrade from standard plan as there are no other options available.
This is time sensitive as we build the trust between the Product team and JPD platform.
Thanks for all you guys are doing in the background!
@Tanguy Crusson could you please also increase the JPD automation limit for my account?
https://educationstandards.atlassian.net/
My use case is
JPD calculated fields don't work for this use case, since they appear blank in JQL.
As a work-around, I am using Jira Automation to calculate the score and put it into a number field, which is visible via JQL. It actually works perfectly for my situation, except we have exceeded our limit of 500 automations.
If you could increase our limit, it will be very helpful.
If you can make calculated fields visible in JQL, it will also be very helpful ;)
Done.
@Tanguy Crusson can you also please increase the automation limit in JPD for my account?
We just shifted several internal processes from Trello to JPD and overlooked the 500 automation run limitation. We are scheduled to go exceed the monthly limit and are very concerned as the automation is a critical component to the success of the larger group. Primary automation runs:
Hi @Daniel Boling can you please raise a support ticket and share it with me on tcrusson@atlassian.com? Thanks.
Created support ticket: Request to increase monthly automation runs
Thanks @Tanguy Crusson for your help!
