I want update single select field values based on other single select value. I use this sample code, but I received error "Error while parsing additional fields.Not valid JSON ":
Scenario is : I have tow single select list fields. When I select one option in firs field I want remove some options in second field.
"expand": "projects",
"projects": [
"expand": "issuetypes",
"self": "https://jira.atlassian.com/rest/api/2/project/10240",
"id": "10240",
"key": "JRA",
"name": "Jira (including Jira Core)",
"avatarUrls": {
"48x48": "https://jira.atlassian.com/secure/projectavatar?pid=10240&avatarId=17294",
"24x24": "https://jira.atlassian.com/secure/projectavatar?size=small&pid=10240&avatarId=17294",
"16x16": "https://jira.atlassian.com/secure/projectavatar?size=xsmall&pid=10240&avatarId=17294",
"32x32": "https://jira.atlassian.com/secure/projectavatar?size=medium&pid=10240&avatarId=17294"
"issuetypes": [
"self": "https://jira.atlassian.com/rest/api/2/issuetype/10000",
"id": "10000",
"description": "",
"iconUrl": "https://jira.atlassian.com/secure/viewavatar?size=xsmall&avatarId=51505&avatarType=issuetype",
"name": "Suggestion",
"subtask": false,
"expand": "fields",
"fields": {
"summary": {
"required": true,
"schema": {
"type": "string",
"system": "summary"
"name": "Summary",
"hasDefaultValue": false,
"operations": [
"set"
// other fields removed for brevity...
"components": {
"required": false,
"schema": {
"type": "array",
"items": "component",
"system": "components"
"name": "Component/s",
"operations": [
"add",
"set",
"remove"
"allowedValues": [
"self": "https://jira.atlassian.com/rest/api/2/component/36920",
"id": "36920",
"name": "System Administration - Support Tools"
"self": "https://jira.atlassian.com/rest/api/2/component/43995",
"id": "43995",
"name": "User Management - Delete User"
Thank you for your reply.
Is there any commend to remove options from single select list?
don't know. I would ask the app devs.
Best
JP
HI,
check, if the forward slash in
Component/smust be escaped...
Best
JP
