×I am trying to set up automation based on reporter domain. I have set it up as follows
WHEN
Issue is created
IF
Issue matches Reporter Domain = "com.au"
THEN
Change Client Location "Australia"
When I check the logs is says not executed?
Additional Info:
Reporter Domain is a custom field that pulls the domain from the sender and client location is custom field containing UK and Australia as the options
Hi Olly,
what does the "Show Details" display?
Susan
