I have 1 more question.. I am trying to create an automation where it will add a comment to the issue and notifying the peer reviewer.. I am running into a bit of trouble implementing it though.. here is what I have so far:
My issue is I am unable to get the automation to insert the custom field 'Peer Reviewer' in to the add comment section as it just returns the following when an issue is created:
Hello Dean,
Try using {{issue.Peer Reviewer.displayName}} instead of ${Peer. Reviewer}.
Please put the exact custom field name after ". "
Rakesh
Hi Rakesh, unfortunately that didn't work. Perhaps I will need a plugin of some kind?
