Clear linked issues using Behaviours using setFormValue()
Steven Mustari
June 18, 2020
I'm trying to clear a form value from the linked-issues field using behaviours.
I've tried the following three ways and none seems successful:
def rt = getFieldById(getFieldChanged())
def links = getFieldById("issuelinks")
def linkType = getFieldById("issuelinks-linktype")
def linkIssues = getFieldById("issuelinks-issues")
def rtValue = rt.getValue()?.toString()
switch(rtValue) {
case "Duplicate":
links.setHidden(false)
linkType.setFormValue("duplicates").setReadOnly(true)
linkIssues.setRequired(true)
break
default :
links.setHidden(true)
linkType.setFormValue(-1).setReadOnly(false)
//None of these seem to work correctly//
linkIssues.setRequired(false).setFormValue("") <--- FIRST WAY
linkIssues.setRequired(false).setFormValue(null) <- SECOND WAY
linkIssues.setRequired(false).setFormValue(-1) <--- THIRD WAY
break
Any assistance would be appreciated!
Steven Mustari
Azfar Masut
April 26, 2022
from scriptrunner support:
This is a bug: SRJIRA-5851
linkIssueField.setDescription("<script>AJS.\$('#issuelinks-issues').val(''); AJS.\$('#issuelinks-issues-multi-select .representation .items em.item-delete').click()</script>")
Instead of setFormValue("") and all the other options I've tried, we're using JavaScript to remove the linkIssueField value.
vishal goyal September 13, 2021
Need a help, is there a way to restrict the search also for this issue link field, lets say i want the issue to come up for one project only which must be available for users to link?
Regards
Vishal Goel
Mathis Hellensberg
June 18, 2020
Hi @Steven Mustari
From which screen are you trying to accomplish this?
Steven Mustari
June 18, 2020
Hello @Mathis Hellensberg
From a transition screen. Everything is working correctly except for clearing the value of "linkIssues".
The only problem are the following lines:
Steven Mustari
Mathis Hellensberg
June 18, 2020
What kind of field is linkIssues? :)
Steven Mustari
June 19, 2020
@Mathis Hellensberg
It's half of the composite system field "issueLinks".
It can be broken down into editing either of the two sub-fields:
issueLinks-linktype:
issueLinks-issues:
(This is the field I'm trying to clear)
Here is a link to the documentation explaining this.
Thank you for your help,
Steven Mustari
SERVER
VERSION
8.5.1
