Custom check box field does not appear to work in JIRA Service Desk
Ed Gaile
September 12, 2014
I added a new custom field to JIRA - I set it as a multi-select check box field
and provide several options
I then add it to a Service desk request type.  When the Service desk portal displays, the field is not checkboxes but looks to be a multi select drop down
I would much prefer the check boxes to show so the user can just click the systems they want access to - is there an issue with the check box field in Service Desk or am I just not setting something up correctly?
Thanks!
-Ed
maccamlc_old_atlassian
September 14, 2014
I can confirm that this is a known bug, and is being tracked by https://jira.atlassian.com/browse/JSD-478.
I would encourage you to add yourself as a watcher to the bug report, so that you will be aware of when it is being worked on, and completed.
