JIRA Service Desk New Installation
Database on MS SQL Server 2014 (jirauser has dbo role on database, jiraschema was created schemaowner is jirauser)
By configuration step set administrator account
Error: User can not added. All User directorys are write protected.
What can I do?
Best Regards
Mario
The error is found.
Solution: jirauser additional role on database db_datawriter and db_ddladmin
Mario, It appears you're unable to create an admin account during the JSD installation wizard. The following links might helpful in this situation;
You might also take a look at MS SQL server configuration for JIRA at;
Hope this helps.
Thanks for your reply.
Yes, it is during the installation wizard.
The two links I had unfortunately reviewed without success.
