×Hi, I'm trying to sort issues by Priority in a queue. I'm using this JQL:
resolution = Unresolved ORDER BY priority DESC
But it does not work. The issues are not sorted by priority. See:
Anyone can help ? Thanks!
An admin in your instance needs to order the overall priorities list in the Admin area... not related to the Priority list being used for your project alone. It is a manual reordering and may be tedious if there is a long list of priorities in your instance.
Have no idea how but it's still repro in 2020
another post revealed the solution to this issue
navigate to <servicedesk>/secure/admin/ViewPriorities.jspa
The set the order, Seems to be multiple ways to set the priority, looks like only the method above works.
Good morning,
I am actually experiencing the same trouble (running verion: 7.8.01).
Any suggestion?
Thank you
Alice
Hi!
What happens when you click on the column header?
