Problem with ORDER by priority in queues
Marc-André Lanciault
Hi, I'm trying to sort issues by Priority in a queue. I'm using this JQL:
resolution = Unresolved ORDER BY priority DESC
But it does not work. The issues are not sorted by priority. See:
Capture.PNGAnyone can help ? Thanks!
Wendy D
April 9, 2021
An admin in your instance needs to order the overall priorities list in the Admin area...  not related to the Priority list being used for your project alone. It is a manual reordering and may be tedious if there is a long list of priorities in your instance.
Maksym Hrecheniuk
July 15, 2020
Have no idea how but it's still repro in 2020
gerry murphy May 2, 2019
I am seeing the same issue, Curious how this can be fixed
another post revealed the solution to this issue
navigate to <servicedesk>/secure/admin/ViewPriorities.jspa
The set the order, Seems to be multiple ways to set the priority, looks like only the method above works.
Alice Ferrari November 14, 2018
Good morning,
I am actually experiencing the same trouble (running verion: 7.8.01).
Any suggestion?
Thank you
Alice
Grigory Salnikov
October 10, 2018
Hi!
What happens when you click on the column header?
