Automation Rule Help
Olly Furr October 25, 2017
I am trying to set up automation based on reporter domain. I have set it up as follows
WHEN
Issue is created
IF
Issue matches Reporter Domain = "com.au"
THEN
Change Client Location "Australia"
When I check the logs is says not executed?
Additional Info:
Reporter Domain is a custom field that pulls the domain from the sender and client location is custom field containing UK and Australia as the options
Susan Hauth _Jira Queen_
Hi Olly,
what does the "Show Details" display?
Susan
Screen Shot 2017-10-25 at 14.37.34.pngThis is a screenshot of "show Details"
