I need the comment to be specific but i have no idea what the condition is meant to be? Can anyone help please as i am a beginner.
Hi Robert,
In my fast-track transition listener, I set it up to fire on "Issue Commented" events.
For my condition, I wrote a script that gets the last comment on the issue and searches the comment for a specific email address. If the comment contains that email address, the condition will return true and the fast-track will execute the transition.
def issue = event.issue as Issue
def commentManager = ComponentAccessor.getCommentManager()
def commentBody = commentManager.getLastComment(issue).getBody()
if (commentBody.contains("email@address.com")) {true}
Simply change text in the quotes to match what you want to look for.
Hi Joshua, thanks so much for your quick reply. I have set this up and it works perfectly! Thanks so much for your help :)
Glad to hear, Robert! Thanks for using ScriptRunner. :)
Josh
