How to create a custom automation and filter by reporter's email domain?
bc
July 17, 2018
Trying to create a custom automation where the rule will filter by a reporter's email address domain (for example @gmail.com) then send the appropriate custom notification.
What is the correct syntax?
Tried using this but it is not accepting it:
reporter = "*@gmail.com"
Prakhar Srivastav {Appfire}
July 18, 2018
Hi @bc
The Atlassian Jira Toolkit Plugin  provides a custom field type "Domain of reporter"
Add a customfield of this type to your view screen ( to check it works) and make sure it has a text searcher. You can then search those custom fields directly with JQL (after doing a reindex).
Regards
Dieter
bc
July 18, 2018
Exactly what I needed.  Many thanks!
brainstem
September 1, 2022
Fabio Martignago April 5, 2019
Hi guys,
I'm looking for the same feature, but in the cloud JSD environment the Java Toolkit Plugin is not available.
Can you help me?
thx
Nate Smith May 11, 2020
Hey @Fabio Martignago
Did you have any luck with this? I am needing the same thing.
Nate
