Issue Security lock icon doesn appear in my issues
Mark_Vincent_T__Paril
Hi Atlassian Community,
I have setup my issue security scheme for our service desk project, however, according to documentation, a lock icon should appear on the upper right corner of my issue. In our case, it doesn't appear there so I can't set a security level for the specific issue
Can you help me with this?
Thank you!
Phyllis C July 20, 2023
Is this "Security Level" field still a valid approach - I seemed not able to find it anywhere as of July 2023 in our cloud instance.
shetty
June 1, 2020
@Mark_Vincent_T__Paril
Make sure you have set issue security permission. if you have that, only then you would be able to see it2.JPG
Hi @shetty yup, I already set the permissions too.
But anyway, I have already found the problem on why it wasn't showing up, I found out that I have to also set the Security Level field in my screens for it to show up. Now I can see the lock icon on the upper right corner of our issues
Thank you!
Like # people like this
Rim CHATTI
Hi! How can i set the security level field in my screen?
I can't find the security level icon on my tickets.
Thanks in advance
Diane Kramer June 10, 2021
I have this problem too.
Rim CHATTI
You should add the field : security level in every screen you're using. Then configure the field to make it visible in field configuration
