Problem creating an automation with issuetype
Maurício Britto September 8, 2020
When creating an automation, I need to put the issuetype field in the THEN clause, but it is not available in the list.
I use the JIRA Service Desk 4.12.0 and Jira Software 8.12.0
Can you help me?
Best regards
Mauricio Britto
Fahad Siddiqui
September 17, 2020
@Maurício Britto please accept the answer so that its how completed and others can also get benefit.
Fahad Siddiqui
September 8, 2020
@Maurício Britto can you please clarify more from were you are trying to automate the issue filed.
Maurício Britto September 9, 2020
Yes, I'm sorry
I need that based on a condition the value of the issuetype field will be changed. The condition I can insert, but in THEN the issuetype field is not in the list for selection.
Fahad Siddiqui
September 9, 2020
I installed the application you indicated, but unfortunately it didn't work. See image to explain better.
Mauricio
Fahad Siddiqui
September 9, 2020
@Maurício Britto try through project automation.
please check the below link may be this will help to fix your issue.
https://support.atlassian.com/jira-service-desk-cloud/docs/when-if-and-then-statements/
Maurício Britto September 15, 2020
Good Morning
I checked the link, but don't exist a solution for my necessity
Thank you for your time
Fahad Siddiqui
September 15, 2020
What automation you are trying to implement?
When a issue created, the system must change the issue type according to a specific value of a custom field
Fahad Siddiqui
September 15, 2020
@Maurício Britto you can easily do this through project automation.
Yes, but the probleme is the same:
When creating an automation, I need to put the issue type field in the THEN clause, but it is not available for selection.
Fahad Siddiqui
September 15, 2020
Dear, there is another option it's called project automation...check that you will fix Ur issue..let me know if anything else required from my end
Sorry, I'm a new user of the jira service desk, can you tell me where I find the project automation? If possible send a screen image
Thank you
Fahad Siddiqui
September 15, 2020
@ sorry i can't send screen shot now.
But You can find it once you click on project settings at the buttom.
Then in second row you will find project automation field..
Hope this helps you
This is exactly what I'm using
Fahad Siddiqui
September 15, 2020
No...the name is project automation..and the above screen shot which you have send before it's only automation and also the location is different
Sorry, but the "project automation" is available on the Jiraservice server? I can't find it on the path you indicated
Fahad Siddiqui
September 15, 2020
Maurício Britto September 17, 2020
Good Morning Fahad
I performed the test with the project automation, and it worked
thanks for your help and time
Like Fahad Siddiqui likes this
