I tried to do automation for an SLA, but it doesn't trigger even though 28 issues have already exceeded the SLA time.
If the SLA was violated during all processes, a mail should be sent. The action is not performed.Thanks in advance. Regards Nicole
Hi Nicole,
Is the user nweiser a customer or an agent? Because the Alert User only works for agents.
Did you check the log for this automation to see if it was "successful"?
Susan
Yes, meanwhile i've restart the jira server and it works.
Thanks a lot for your anwser.
Regards
Nicole
