×Can some one help me please... I am wanting to automate the process of email requests and putting them into groups.
For example - if a client app is down and the request is an incident not a service request how can I automate this with the SLA's and queues.
Hi Stacey,
Service Desk automation can read incoming email and based on keywords change a request type. So if the email said incident it could change the request type.
But the issue type would have to stay the same. But then the SLAs and Queues can be customized based on the Request type.
Hope that helps
Susan
Yes brilliant!
Do you know where I can automate the emails.
Stacey
Hi Stacey,
You need to first set up your service desk to receive email and ensure that you have a customer request type for receiving email (e.g. Email request). It can only have summary, description fields.
https://confluence.atlassian.com/servicedeskcloud/receiving-requests-by-email-747602718.html
Then you use the Service Desk Automation:
https://confluence.atlassian.com/servicedeskcloud/automating-your-service-desk-732528900.html
Cheers
Susan
Thanks for this!
I cant seem to get the automation to work I'm sorry!
I apply the rule but nothing happens and it still goes into the service request queue when I need it to go into the incidents queue if stated in the email urgent etc...
Hi
Did your check your automation log to see if it worked. Otherwise paste a pic of it in here
S
Ive checked the log and it isn't executed I have no idea how to get this to work
Just checked all my rules and nothing is executing at all
@[deleted], can u provide an image of your automation steps and maybe an example of email used to test?
