problem after deleting custom field
Rachid Amajoud June 21, 2018
in my Jira Service Project, i created a new custom field with the dropdown type in place of the radio button, so i unchecked the old custom field from the fieldscreens that i used before and replaced it with the new custom field. Now  i get the following problem:
Jack Brickey
@Rachid Amajoud, you can reach out to Atlassian here. This assumes you have something other than a starter license (10 users). I will try to assist here in the community a bit later if still needed. Please update this thread if you do open a case with Atlassian.
Andy Heinzer
June 21, 2018
Hi @Rachid Amajoud I created a support request on your behalf, please see https://getsupport.atlassian.com/servicedesk/customer/portal/3/SDS-33738 for more details.
Jack Brickey
Thanks Andrew!  I was just getting back to this thread.
@Rachid Amajoud, please update this thread once you get your answer.
Rachid Amajoud June 25, 2018
thx guys, i found a solution! I just made new request forms and there are no problems with older requests! I can change the status of older requests without any problems.
grtz
Rachid
can we setup a teamviewer session, so you can take a look?
Moses Thomas
@Rachid AmajoudThis is a community,   you  might need to  wait  and see may  be some one has   an answer to  your problem  which  i can  not  figure out at  the moment, in  as much  as  i  will  love  to  help  but  i am  at  place  of work  now  and if its  really  critical  for you to  fix this   then  please you  should highly  consider atlassian   support .
Best regards,
I wish  you  best of luck.
Okee thx a lot Thomas!
grtz
R.
How do  I get support from Atlassian?
Moses Thomas
@Rachid AmajoudIts  clear  so  please  click  the link  at  the end " add values to  field to fix  all  request forms"so  you  must  add  values  to the new field .
Hi Thomas,
that's what i am trying to do, adding this field to the forms, but when i cllick the edit button on the request forms, i get this error on a blank page, not possible to add something. In addition a video about the issue.
https://drive.google.com/open?id=1QiYi8v1zOAKJTcBI0gZUxnWjWdH_pK-o
grtz
R.
Moses Thomas
@Rachid AmajoudI have seen  the video,  could you  check all field configuration of these screens ,  is this field   required or  optional ?
the field was required!
Moses Thomas
@Rachid AmajoudSo  make it optional  and try  again  lets see.
Thomas, how? i think the setting to make this optional is on the setting page of the request type pages, when i open this, i get the error as you can see on the video.
grtz
R.
Moses Thomas
@Rachid AmajoudYou can  make it optional in  field configuration,   when  you  click  on the  field configuration  used by  this screens you  will  see the optional  option.
Thomas,
indeed i did that too, but nothing changed! :-(
Moses Thomas
@Rachid AmajoudDid you  do  only  project re-indexing  or  Whole system re-indexing ?
whole system re-indexing.
Now i did a project re-index too. No difference.
Moses Thomas
@Rachid AmajoudYou must  have deleted the wrong  field You  may  want to  raise  a  ticket for this one in  atlassian   support
Good Luck.!
Thomas,
I deleted the correct custom field, but i did this when they were still requierd on the resuest type pages. I need a way to make them optional on that page!
grtz
R.
Moses Thomas
@Rachid AmajoudI  know I saw the video :  this  makes  it the wrong custom  field because it is required when  you deleted it. Now i am  wondering  how you  could do it from  Database clear record of the old one,  but we don't know custom_field Id.
Could your recover you  Jira instance from  back_up ?
at this moment isn't an option :-(
s it possible to do just a role back of the Jira Service Desk project?
Hi Thomas,
re-index process finished, but the problem is still there. :-(
Other options?
grtz
R.
Moses Thomas
@Rachid AmajoudThe  new custom field have you  set  values for it ? and this field which  has been  shown  on the screen   that  says  it has no  values is it the new one  ?
Hi Thomas, it is the new custom field with the same 'fieldname' the only difference is that the fieldtype isn't a radiobutton but a dropdownbox. The values are the same.
grtz
R.
 I get this error when i want to edit the request types in JSD.
grtz
R.
Moses Thomas
@Rachid AmajoudI think  you  should perform  re-index ( back-ground  preferred)
Note this could take more time depending  on  how large is  your instance.
Best!.
Thomas,
i just started the re-index process, i hope it will solve this problem!
grtz
R.
