script runner basic help
Karthik Mohan November 28, 2017
 would like to write a script which calclautes the differnce between two date fields and display the result as number of days in a custom text field.
Field 1 : start date
Field 2 : end date
Field 3 . total number of days.
Expected result:
Filed 3 = field 2 - field 1
after a lot of search and suggestions i chose the script runner plugin. But i dont understand how this script runner plugin works and where should i start writing my script.
Insights will be much helpful for a newbie
Alexey Matveev
November 28, 2017
Do you have Cloud version or Server?
Hi Alexey,
Thanks for the reply. I have a cloud version
Alexey Matveev
November 28, 2017
You need to create 3 custom fields. Then you have to add a scriptrunner post function for the transition where the third field must be calculated. The code for the post function would be like here
http://scriptrunner-docs.connect.adaptavist.com/jiracloud/post-functions.html#_calculated_custom_field
by custom field you mean the available date picker fileds rights ? or should i create my own custom fields..
Alexey Matveev
November 28, 2017
yes, available date picker fields
cool, where should i add my script. should i write my scriot on the script listener or some where else ?
Alexey Matveev
November 28, 2017
into post function. open desired transition and add scripted post function
Hi @Alexey Matveev i tried like what you said. but i am not able to see the expected reasult..
// custom field references
// date picker 1
def startdate = 'customfield_10401'
// date picker 2
def enddate = 'customfield_10403'
// text field where i want my result of the date difference calculation
def totaldays = 'customfield_10406'
// Extract the existing values from the issue
def sdate = issue.fields[startdate] as Integer
def edate = issue.fields[enddate] as Integer
if (sdate == null && edate == null) {
// No date's was specified, we can't calculate the date
return
def tdays = issue.fields[totaldays] as Integer
// Calculate the days
def days = edate-sdate
put("/rest/api/2/issue/${issue.key}")
//.queryString("overrideScreenSecurity", Boolean.TRUE)
.header("Content-Type", "application/json")
.body([
fields:[
(totaldays): days
.asString()
thats the script i used
Alexey Matveev
November 28, 2017
I think you have problems with converting dates. You need to use date arithmetic. The code which substract dates would look like this
def duration = groovy.time.TimeCategory.minus(
  new Date(),
  new Date(session.creationTime)
def values = [
            "seconds: " + duration.seconds,
            "min: " + duration.minutes,
            "hours: " + duration.hours,
            "days: " + duration.days,
            "ago: " + duration.ago,
You totaldays custom field must be numeric not date picker.
Unfortunately, I can not check your code because I do not have Jira Cloud. I have only Jira server and scripts are different there since rest api is used in Cloud and in server - jira api.
Hi @Alexey Matveev
I am getting an error "the variable [issue] is undeclared.
How should i handle this.
