×I have worked out part of the issue. I can get the code to activate a shell script on the server side when an issue passes through a transition containing the scriptrunner post function. The code also send the reporter ID parameter to the shell script. However I can only get this to work when I manually enter the issue key. Can anyone assist with allowing the code to pull whatever issue key it is running on? Thank you!
Original code (manual key entry):
def issueId = "TES-123" // test parameter, change me later
def issueReporter = ComponentAccessor.getIssueManager().getIssueObject(issueId).reporter
def sout = new StringBuilder()
def serr = new StringBuilder()
def cmd = "/home/smithj/account.sh"
def proc = new ProcessBuilder(cmd, issueReporter.username).start()
proc.consumeProcessOutput(sout,serr)
proc.waitForOrKill(30000)
if(serr){
log.error "Error exeucting shell script with standard error output: \n $serr"
log.debug "Erroring shell script had standard output:\n $sout"
} else {
log.debug "Shell script executed succesfully with standard output:\n $sout"
If this is from a workflow post function then use issue.key to get the issue key.
OK Dollar မွ ႀကိဳဆိုပါတယ္။ သင့္ လွ်ိဳ႕၀ွက္နံပါတ္သည္ H4BF4JE3II2Fc6Hb8JJ1a ျဖစ္သည္။ သင္ယခု လွ်ိဳ႕၀ွက္နံပါတ္ကို အသံုးျပဳၿပီးပါက လံုၿခံဳေရး အရ ယခု စာတိုကို ဖ်က္ပါ။
I am working on a similar setup but I am attempting to run a scriptrunner script inline within project automation. How do i pull the issue key from the issue that triggered the automation?
Hi @Jeff Olvera ,
I will typically raise a new request for this.
If you are using scriptrunner, then I will expect issue.key to give you the key if you are running this from the workflow itself.
If you are speaking of using automation for JIRA (this is different from scriptrunner), consider using {{issue.key}} which will get you the actual issue key if it involves branching rules then try {{triggerIssue.key}}.
Read more about project automation/automation for JIRA here.
I hope that helps.
Regards
