×The goal of this article is to help to build out-of-box solutions with Automation for Jira (A4J) and Jira REST API. We will cover how to send a REST API through A4J. This will be useful to automate a REST API action. For instance, when an issue will be created, we can add a new field option into a field type e.g: "Select List (single choice)".
We would like to point out that using Jira REST API with A4J opens many opportunities to build great workarounds to resolve possible issues. :)
We will cover the trickiest part of this rule, which is the REST API configuration. Considering this, let's follow the steps below. We'll explain how to make this as we go:
1. We need to generate the API token associated with your Atlassian account within Jira. For this, we can follow this documentation: API tokens - Atlassian Documentation.
2. Then we need to encode the credentials "<EMAIL>:<API_TOKEN>" with base64. We can make this through any online tool like Base64 encode.
Note: Make sure not to include a line break at the end.
Apart from that, it's possible to Encode to base64 through terminal:
$ echo -n "email@example.com:<YOUR_TOKEN_HERE>" | base64
3. Into the rule action, we can use all Jira REST API available in Jira: (The Jira platform REST API).
E.g.: https://<jira_instance>/rest/api/3/customField/10287/option
Make sure to include the entire instance URL: my-instance-.atlassian.net.
4. Add the Headers with Authorization Basic "<EMAIL>:<API_TOKEN>" encoded to base64.
E.g.: Authorization Basic HzxuhHbhzhdjasYTgdjGfrGHzxuhHbhzhdjasYTgdjGfrG
5. HTTP method: in this case, we'll send the web request by POST, however, it's possible to use other methods like GET, PUT, DELETE.
6. Webhook body: select Custom data to be able to send the JSON data.
7. Then, in "Custom data" we can add the JSON payload.
Example from Jira REST API:
Send web request example:
Note: Select the option “Delay execution of subsequent rule actions until we've received a response for this webhook" if you want to receive the answer into {{webhookResponse.status}}. With this log action below, the webhook response will be printed on the audit log.
Hope that this article helps everyone! :)
Cristiano
63 comments
