Jira Cloud Automation - Create a project with shared settings from a template project with Rest API
It was a challenge to create a project in Jira cloud from a template project by using Rest API's. After doing some research , I found some hidden API's and here is a way how you can use those API's and can create the project.
By following below api's you can achieve following.
  • Create a project from existing project settings
  • Copy the board from existing board and associate with newly created project
  • Change the board name, filter, location for the board.
Create a project from template
This API will create a project with shared settings same as in existing project.
Request URL: https://yourinstance.atlassian.net/rest/simplified/latest/project/shared
Request Method: POST
{"name": "newproject name", "key": "newprojectkey", "existingProjectId":"10000"}
Copy the agile board
This api will copy the agile board , which you can associate later on with newly created project
Request URL: https://yourinstance.atlassian.net/rest/greenhopper/1.0/rapidview/<boardid>/copy
Request Method: PUT
Change the project location of the board
This api will change the board location which is the newly created project name
Request URL: https://yourinstance.atlassian.net/rest/greenhopper/1.0/rapidviewconfig/boardLocation
Request Method: PUT
{rapidViewId: boardid, locationType: "project", locationId: "destination project id"}
Create the Board Filter
This api will create the filter for the new board which you recently copied
Request URL: https://yourinstance.atlassian.net/rest/api/3/filter
  "jql": "filter query",
  "name": "filter name",
  "description": "filter description"
Change the board filter
This api will help you to change the filter which you created above for the copied board
Request URL: https://yourinstance.atlassian.net/rest/greenhopper/1.0/rapidviewconfig/filter
Request Method: PUT
{"id": boardid, "savedFilterId": "saved filter id"}
Rename the board name
This api will help you to rename the board name
Request URL: https://yourinstance.atlassian.net/rest/greenhopper/1.0/rapidviewconfig/name
Request Method: PUT
{"id": boardid, name: "new name"}
We are done here, Please feel free to add your remarks for any improvement.
My blog reference for the actual post:
Request Method: PUT
Request Method: PUT
Request Method: PUT
Request Method: PUT
Request Method: PUT
Request Method: PUT
Request Method: PUT
Request Method: PUT
My blog reference for original post:
https://www.techclimbs.com/2021/05/jira-cloud-create-project-with-shared.html
2 comments
Andrey
July 22, 2022
Thanks for this topic. But I would append some details to here:
There are not important things about boards`s owner that need to be replaced by /rest/api/3/filter/{filterId}/owner and then we need to send request for changing permission /rest/api/3/filter/{filterId}/permission
Fazila Ashraf
Hi @Muhammad Ramzan_Atlassian Certified Master_
Many thanks! How to check for other REST api endpoints that are not documented or publicly visible?
